Will do. You could come by and look at my setup too while you're here. Message me if you want to.
The other cat's meow thing is that controller of cpeltier! Did you put that together yourself? It's awesome.
You need a sensor, perhaps hooked up to odr, that will beep upstairs when it's time to load wood before things get too cold
I've gone to the website but it's not clear to me: does the integration require assembling it onto a circuit board, soldering it on, etc? I'm a noob when it comes to that but I'm looking for a hobby.I put the controller together or rather integrated it. Fairly straight forward, nothing terribly complicated.
Thanks for the offer, I can't do it on this trip but I will catch you next time I am in the area. Looking forward to meeting you and learning about your setup. Thanks for all the helpful information!Will do. You could come by and look at my setup too while you're here. Message me if you want to.
I bought it here:I've gone to the website but it's not clear to me: does the integration require assembling it onto a circuit board, soldering it on, etc? I'm a noob when it comes to that but I'm looking for a hobby.
Like I said, a lot of smart people with a lot of amazing technology. I am a bit more in the plug and play world.Wow, I'm looking into this. As I said, I need a hobby.
I am more of a story/experience guy vs. #'s so here is a quick story. I started a fire yesterday morning at 7:00 and asked my wife to start a fire last night. She forgot and forgot again this morning. She just called me (4:00 PM) and asked if she should start a fire (tank was at 117) NOT calling to tell me that the house was freezing - it was still at 72. I know the propane did not kick in because I have the setpoint at 110. It was in the upper 20's yesterday, around 20F last night and a high of 29 today. NO way that would have happened last year when I was pulling straight from the top tank without mixing.
Im looking forward to see if I can get such reprots from the wifeI am more of a story/experience guy vs. #'s so here is a quick story. I started a fire yesterday morning at 7:00 and asked my wife to start a fire last night. She forgot and forgot again this morning. She just called me (4:00 PM) and asked if she should start a fire (tank was at 117) NOT calling to tell me that the house was freezing - it was still at 72. I know the propane did not kick in because I have the setpoint at 110. It was in the upper 20's yesterday, around 20F last night and a high of 29 today. NO way that would have happened last year when I was pulling straight from the top tank without mixing.
I know I mentioned it somewhere on this thread or another but yes return from a setback is a MAJOR groan. My system uses and Indoor Room Sensor that overrides the Outdoor Reset and will raise the flow temp to drive the Recovery period (usually 20 degrees F or so over the Outdoor Reset target) but even with that it takes a long time. At the end, I am not sure it is worth it.I've been observing low temp, relatively speaking, operation the last few days with my 120 gallon buffer tank (not mixing). I have to say that trying to return from a setback is a groan. I might start a thread on setbacks and cost savings.
(Edit: I can't go too low because my Froling Energy Tank makes dhw with a 1.25" corrugated stainless coil that holds 11 gallons. It works down to pretty low temps. I turn off the zone circs at 120F and back on at 125F while the boiler is getting up to temperature.)
Bring her here, you and I can split some wood, my wife can work with her on reporting.Im looking forward to see if I can get such reprots from the wife
Not sure how you would do average temp (the Effecta does not do this). I have the ability to measure top of top tank, top of lower tank and bottom of bottom tank temps but I haven't done anything with them other than use them as a gauge to know about ow much buring I can do if I want to get to 190 or so.36 hours seems pretty good to me. You have a 1000 gallon tank and you know where you started and where you ended up, average temperature wise. I'm not sure how you would do average temperature-is the temperature gradient in the tank linear? I think not. Then there's issues of not perfect stratification, or whatever else. Anyway, you could figure out, somehow, how many btus you used, which would be interesting. Perhaps your Effecta calculates this for you?
I think setback/recovery is a thread of its own and I would think has been deeply discussed somewhere. On the surface it seems to make sense but as I watch my boiler adjusting to accommodate the recovery I clearly see how much extra energy is required to do so. The you add in the discomfort factor (furniture gets cold, etc.). One of the things I committed to myself (and promised my wife) as I headed into this adventure is that our house would be warm. If it takes a little extra wood so be it.That's something else that I see here that indicates my baseboard was oversized when it was put in. I can recover from setback pretty good. If I'm the only one home during the day (which is 90% of the weekdays here), our upstairs (bedroom) zones are set back to 16c. The thermostats up that to 20c around supper time, and it is 20c up there a couple hours later. The stats back down from 20 to 18 for overnight, at 11pm. I usually use setbacks on all of our zones at certain times to extend my storage mileage. Our largest zone has the kitchen on it. It is set to 20c from 5pm until 11pm. Then sets back to 16c until 6am. Ups to 18c until 7:30am. It's usually 7am before someone makes it down there, by then after an hour of heating it is feeling warm, temp usually shows 17c or 18c. That's if I let the stats do what I have them programmed to do - I will also quite often bump them up manually a degree in the evenings or when burning, especially the kitchen one, to put more heat in the house. So I 'set ahead' some also. Our 4th zone has the living room & my office on it, with a manual stat. I drop it a couple degrees on the way to bed, then up it as needed during the day.
If we're gone for the day and I need to heat the whole place up at once (could be from 2c to 4c) when we get back when I get a fire going, I don't have much if any boiler water going to storage for the first couple of hours. But by then the house is pretty well up to temp and water starts going to storage.
Maybe more emitters as maple has would helpI know I mentioned it somewhere on this thread or another but yes return from a setback is a MAJOR groan. My system uses and Indoor Room Sensor that overrides the Outdoor Reset and will raise the flow temp to drive the Recovery period (usually 20 degrees F or so over the Outdoor Reset target) but even with that it takes a long time. At the end, I am not sure it is worth it.
Possibly but I don't have much wall space left for any more baseboard. In my case though I don't think it would matter because my controller is controlling the flow temps. If I had more emitters I think I would be using a somewhat lower heat curve which means I would have lower flow temps than I have now so I think I would be back at the same exact place. Someone good with details could probably do the BTU's saved vs. the extra BTU's used to recover and determine what % benefit, if any, there is associated with setback and recovery.Maybe more emitters as maple has would help
Honestly my recovery takes longer than I would like. I often think about not using it but since I have the Energy Saver feature built in the little kid in me wants to use it.Also John's house even though he has fin tube might be pretty tight with enough radiation for all this to work. I think outdoor reset with indoor feedback's success from storage is dependent on enough radiation and a relatively tight house, that should be first looked at.
I think it might need further discussion from a low flow temp perspective. I don't remember too much of that.I think setback/recovery is a thread of its own and I would think has been deeply discussed somewhere.
