Hi, I found my way here after our 6039 that we purchased new about ten years ago started burning poorly. A Google search sent me and found my answer. Thank you.
I originally planned to burn corn but found it not so easy to get locally or expensive. As a result it has never burned anything but pellets. At first while we were still working we used 2.5 tons of pellets a year. Since retiring and spending half the year in Florida and half in NY it's more like twenty bags. It will be more this year since here it is May and it's still crappy in NY. Came back north a little too soon I guess.
The fix to the poor burn was a good cleaning. After watching a YouTube video linked here I discovered I had not been cleaning my stove properly. I had always cleaned the burn pot and scraped off any carbon build up but never thought to soak it in hot water. The ceramic brick immediately broke when I removed it, my second replacement installed now. I also put 1 1/2" knock out plugs in the two holes behind the brick as suggested in a post I read. What is the purpose of the holes and why do you plug them? BTW Amazon has the brick Prime for $40 about half of every other source. The new one seems to be a little more solid. When I pulled the draft fan to clean it the gasket pulled apart. If you plan to pull yours and use the stove right away it might be a good idea to get one first.
One other thing I had to replace was the glass. Last summer we had the siding replaced on our house and some how while banging away on the outside the siders manage to crack it. A local hardware store made up a perfect high temp glass replacement at a fraction of the cost of one from USSC.
I also learned a new acronym "OAK" outside air kit. I have an OAK. I tried it with the cap off and with three holes drilled in the cap. I burns better with it off. I also put a piece of stainless steel screen inside the intake box to prevent any insects from entering. While we are away I tape off the OAK and remove the hood from the stovepipe and cap it off to stop cold air from entering.
Sorry to be so windy. I though I would say thanks and share my experience with my stove that is keeping us toasty on an really rainy cold day. Mark
