Hello.
I just scored a Aladin Quadrafire 1000 built in 1992. The previous owner's husband had tinkered with it and has passed so I was the lucky one on Craigslist to remove it for her.
Upon initial inspection I found a damaged Power cord, missing fuse holder cap and #1 Snap Disc missing. (even the connectors! someone clipped them)
I also found the Vac Switch was bypassed.
So I replaced the fuse holder with another one from Radioshack as The cap to the one I bought wouldn't fit. Replaced with a 7 amp fuse, Repaired the power cord (planning on replacing shortly) and decided to leave the vac switch bypassed for testing.
Removed the old pellets/debris from the hopper and plugged it in. As expected the Combustion blower engages just fine. And after about 8 min it shuts off. Per the manual.
I have hotwired where the Thermostat hooks up but I never get a Red call light. If I am reading the manual correctly I have found. The Stove should engage the Combustion blower motor (which it does) and once the Thermostat calls for heat (jumped) it should turn on the red light and start the auger and at some point attempt to ignite the pellets.
If I am missing something here, please point it out. So my question is, How do I diagnose the issue at hand and diagnose if I have a control box issue or other issue?
I will be ordering a new snap disc and vac switch but I want to diagnose all the needed parts before I make a order (pay shipping 1 time) .
Also.. Not sure if this matters but I was able to test the voltage at the thermostat terminals to 14VAC and remembered reading that it required a 24 volt thermostat.. Is that the correct voltage or does that indicate an issue with the Transformer in the Control Box?
Appreciate your assistance.
"I have hotwired where the Thermostat hooks up but I never get a Red call light. If I am reading the manual correctly I have found. The Stove should engage the Combustion blower motor (which it does) and once the Thermostat calls for heat (jumped) it should turn on the red light and start the auger and at some point attempt to ignite the pellets." and it does nothing. no red light, no auger.
