I have a masonary fireplace that we recently put in a Heat n Glo vented fireplace. I am experiencing a terrible draft coming in from the bottom of the insert. My temperature gun reads between 27 and 30 degrees - it is currently 17 degrees outside. This draft is constant is affecting the temperature in my home.
I am trying to figure out where the draft is coming from so that I can plug / seal the hole. I have also reached out to the store that installed this but they are saying that it could be a few weeks before they can get someone out here.
I have a full brick chimney with an ash clean out in the back of the house. I took picture inside the cleanout and as you can see from the picture that I zoomed in on the romex power cord and the black gas line is visible - I do not think I should be seeing that!
I also am not sure if or where the fireplace is sealed from the top of the insert to the top of the chimney.
![[Hearth.com] Help fix my draft! [Hearth.com] Help fix my draft!](https://www.hearth.com/talk/data/attachments/219/219157-79d44ecd0924f4e65dda7a8593b0d7b4.jpg?hash=p_8n8L3lsu)
![[Hearth.com] Help fix my draft! [Hearth.com] Help fix my draft!](https://www.hearth.com/talk/data/attachments/219/219158-42c706ed975b328b5abe090eb8c2c793.jpg?hash=3E9DiVcXyk)
any help would be appreciated as right now I have a towel in front of the fireplace to attempt to block the air
![[Hearth.com] Help fix my draft! [Hearth.com] Help fix my draft!](https://www.hearth.com/talk/data/attachments/219/219159-58a1194c3dca4bc42647456882631509.jpg?hash=MpS6ftn7H-)
The stockings will actually sway a lil if I remove the towel.
Any help would be appreciated!
Thanks!
Thanks!
