HELP Harman P35i wiring
Kinger37
3
Enfield ct
Installing my Harman P35i. Trying to wire the ground from the power cord. It says it the ground goes on a grounding post located on the feeder air I take snout. Where is that??
Look for the other Green wires. They are all grounded to the same spot.
[Hearth.com] HELP Harman P35i wiring
Best I can do. From the manual...
Pick a spot on the body where you won't penetrate the fire box
& drive in a self-tapping screw.
Back it out, put the ring on it & drive it home.
You'll be good to go.
