Hey there,
I’m installing a little propane stovetop/oven in a school bus conversion and running into a couple of issues. When previously installed and hooked up to a 20 lb bbq tank, the oven worked but never reached temp even after hours. After some research I’ve decided to replace our hose and regulator because both are pretty ancient, but that’s where I’m getting confused.
First off, there is a regulator built in to the propane stove, right where the gas hose goes in. If this is the case, do I even need a second regulator at the tank?
Second, if I do, what size of regulator do I need?
Thanks for your help!
