Installer came out and measured my fireplace yesterday for the Lopi Declaration that I already ordered. (I already ordered because I got a quote from another place on the same stove, and they measured and said it'd fit.)
It looks like it needs 39" of clearance from the bottom of the insert up to anything combustible. My mantel is quite a bit higher than that, but there is wood facing at 36". It looks like the Declaration does not have a mantel heat shield option. Doh!
For anyone who has a Declaration: is "the bottom of the insert" the same as the surface of the hearth?
Cutting the wood facing back to 39" will be fine, but 40" would be pushing it. In the attached pic, you can see how the wood facing on top is pretty wide. You can also see how there's that convection heat thing in the middle (what is the proper name for that?). So there's that big hole, which is supposed to help hot air circulate out. So I reckon I should not cover that up. But to cut the mantel back 3", the wood might end up partially covering the lower 1-2" of that hole. Is that a problem do you think?
![[Hearth.com] Help - looks like mantel needs modified for Declaration [Hearth.com] Help - looks like mantel needs modified for Declaration](/talk/proxy.php?image=http%3A%2F%2Fwww.hogsmack.com%2Frandom%2Ffireplace.jpg&hash=707a5d065ffaa3e677c95277c0160aa8)
