2000 Enviro EF-4 insert. Had system completely cleaned in October and ran about 1/2 ton of Turmans to date. Perform weekly deep cleans (remove blowers and clean fins, vacuum behind all panels, scrape off all accumulating gunk, vacuum hopper, etc.)
Two days ago I shut it down due to warm weather. Turn it on yesterday and it is being SUPER testy with me. The auger cycles anywhere from 5-10 times then stops feeding completely - no green light indicating system is sending power. Any flame that started will just burn down and flame out from no fuel. Turn it on again once system shuts off, auger cycles 10-20 times and then stops. Igniter gets the first few pellets going and then auger quits out. Continue frustration.
HOWEVER, I can assist the whole operation by turning on the room distribution fan (convection) then turning it off again quickly. If I do this, the auger will cycle 10-20 times then stop again. Turn the fan on/off again quickly, and the cycle repeats. Not sure how this all fits into the equation, but I am at a loss now. Normally I just leave the fan OFF and let the system override it and kick it on when the stove gets to temperature. I tried leaving the fan ON and the auger still quits out, it seems like the initial surge of the fan clicking on and off again is enough to get the auger to reset and cycle a few times.
PARTS I HAVE REPLACED:
Door Gasket (old one was beat, new one is sweet)
Igniter
Auger Motor
I removed the exhaust temperature sensor and cleaned off all the accumulated crud, shined like new again. I have blown compressed air throughout the whole vacuum sensor system (through barb into stove and through rubber tube - no cracks or breaks anywhere). Tonight I may try and jump the vacuum sensor completely to try and rule it out, but I feel like the convection fan would have zero effect if that was the cause.
Any idea on why the fan kicks the auger on for a few cycles? Figure that when the cold air really starts to settle in, the stove decides to go on vacation.
Igniter
Auger Motor
