I live in Danbury, CT. We are not allowed to use outdoor wood boilers. They need to be indoor/epa certified. I was looking at econoburn ebw 200 and Froling S3 turbo 50. My current heating system is a prestige solo 175 and it heats 5500 sq/ft. My house is a combination of forced hot air and hydronic heat (basement/garage slab). My only option is to put the unit in an external garage (165ft away) and run the water lines underground to the house. I plan on adding 800 gallons of hot water storage in my basement and tie it in to my current heating system. I contacted Tarm and Econoburn and I am torn between them. I watched videos of cleaning the econoburn and the Froling and the Froling appeared to be easier. The econoburn had you take the back panel off, cut insulation, and remove a plate that is sealed with silicon to clean the heat exchangers. The process is reversed (apply sealer, tape up insulation...). The Froling looked much easier to maintain with easily removed panels to clean the tubes. Starting the fire also appeared to be easier.
Here are my questions
I plan on heating my external garage that is approximately 1250 sq/ft. I believe the BTU's from the econoburn should be able to handle the garage and the house but I am not sure the Froling is large enough? Total of 6750 sq/ft
Froling is expensive compared to econoburn, is the extra maintainence steps/inconvenience worth the savings?
Does anyone know of local installers in the Danbury CT area? Everyone I spoke to does not have experience with wood boilers.
This will be an expensive investment and I hope it will pay for itself in the short term. Fuel prices will being going up under the new administration.
reason is it was sitting in the Yukon when i decided to go with the Econoburn unit.One of the first gasifyers in the Yukon,and one of the first systems with storage in the Yukon
