first season with stove,i used stove temp mode auto all season due to the extreme cold.now were getting big weather temperature swings.10 degrees in morning and 60 in the afternoon.wanted to set up room temp mode to save on pellets and keep consistant heat.i put stove in room temp mode,manual and put blower on high,set temp.for 72 degrees.the sensor is alongside the stove and i used a temp gun and it showed 74 degrees with the room at 72.so it's close.woke up this morning and downstairs was at 81 degrees,blower still at full blast.i read the sticky and the owners manual and it says,the stove will adjust the feed rate and blower depending on probe reading.i set feed at 4 and left blower on high.do i not fully understand how room temp works.i read the stove probe gives readings to the stove to adjust feed and blower.so shouldn't the stove have kicked down the feed rate and blower to a lower setting?i have been watching stove all day and the blower stays on high if i leave it there or stays on low if i leave it there,stove is not changing the blower speed at all no matter if it's too hot or cold in the room
