help with TP 440 Earth stove we're stumped !
Tye
1
Upstate NY
We have a Tp 440 Earth stove/ natural, and the auger comes on fine during startup for 7 minutes , we are to light for 3 minutes and then the draft comes on for 10 min as it should . At that time the auger is supposed to come on and feed the fire which it doesn't . The red light blinks twice in succession telling us Bad ignition. We have changed the circuit board, no difference, and the auger is working considering it feeds for startup.
There should be a low limit snap switch, also called a proof of fire switch that needs to complete the circuit after so long. If its disconnected or faulty will not continue after the startup. About a $15 dollar or so part. You could jumper it to check my theory.
Reactions: webbie
That switch is located on top of the stove under the granite and is the first one on the left. It is a F110-15 switch though a F120-10 will work of they are easier to find.
Silly how I know this stuff.
