It doesn't look like I will be able to get the stove we had ordered a Quadrafire 4300step top. Don't have any idea when it will get delivered. So I have really started to look into the Hearth Stone Stoves, I wish I looked into these to beging with.Soapstone sounds unbelievable. I love the looks of these behemoth's! In my mind I know what I want, the Mansfield.Why? Long burn times a absolute must, the soap stone is a even heat from what I keep reading so the way I take they don't seem to roast you out. Did I mention I want LONG BURN TIMES. These two stove are almost identical with the space it heats QF 2400sf, the Mansfield 2500sf.
Now this is where you guys are going to tell me I absolutely nuts! My home is roughly 1000sf , house is 30' by 32' built in 1986,all original windows. I'm going to say its moderately insulated compared to the way they are today. The stove would be located almost in the center of the house, in a good-size living room with the kitchen fairly open to the living room, small hallway off the living room with bathroom and two bedrooms off it. By small hallway I mean 9 feet with the three rooms off it. Bathroom on the end and bedroom on each side.
I live in Maine and it can get pretty damn cold here for a good stretch of time. I remember last winter it was down to 20 BELOW a few mornings. Now one man being roasted out of his house might be comfortable for the next, I don't mind 80+ degrees when its 0 degrees out, plus the hotter I have it the less the wife wears around the house!
After all if it get to hot and i mean in the 90's I can open a window
I looked into the heritage which is closer to the SF of my house, I just don't want to have to deal with loading it that much. I want to be able to go to bed and not have to worry about a cold house or starting from almost scratch again in the morning. I want to be able to load her up again and not have to worry about the same thing when I get home from work which is around 8-10 hours later. My wife works the same hours so there will be no one home during the day to put wood in. I want this to be my primary heat source.
I would rather have to much stove then not enough stove. I already suffer the not enough and far from to much on some things the wife says :down: , so maybe I can make up for it with a big ass stove. The bottom line I want heat when its cold, I dont want trouble keeping the house in the 80's on the coldest days we see. And I can back off with the amount of wood I put in it when it is to hot or in the fall spring months.
Let me have it!!
After all if it get to hot and i mean in the 90's I can open a windowI looked into the heritage which is closer to the SF of my house, I just don't want to have to deal with loading it that much. I want to be able to go to bed and not have to worry about a cold house or starting from almost scratch again in the morning. I want to be able to load her up again and not have to worry about the same thing when I get home from work which is around 8-10 hours later. My wife works the same hours so there will be no one home during the day to put wood in. I want this to be my primary heat source.
Let me have it!!
