Hi500 cat lighting up with bypass open
faultymechanics
Burning Hunk
Oct 15, 2020
230
New Hampshire
Is it normal that my cat is glowing even with the bypass is open? I can see flames heading towards and wicking up the flame shield that surrounds the cat. Bypass fully open.
I'm not familiar with Regency but is this after a burn and the CAT has already been in active zone? Could it be just cooling down?
Could this possibly be faulty mechanics?
Pun intended......LOL
Reactions: faultymechanics
It was this morning after I had reloaded on some coals from an overnight burn. Cat temp was definitely below light off temps but was still warm from the burn overnight.
Reactions: all night moe
If flames go there, heat goes there and it's possible it can glow then.
If flames go there with the bypass open, you may have a lot of draft. How tall is your flue?
A bit tall, could be due to that.
Not crazy.
I would not worry about the cat glowing unless you see no flame going to the bypass area (indicating it doesn't really open).
