This saw is somewhat of a pain in the arse. LOL! I started taking it apart last night. I wasn't able to get inside the unit to access the brake; I'm not sure how that's done. I couldn't get the inner part of the clutch off the shaft either.
So I pulled the carb apart again and gave that a really good cleaning. The primer bulb isn't located on the carb, it's located on the saw body. Two lines go into the carb: one from the primer, one from the tank. The mix screws on this thing are odd. They're partially incased in plastic and can only be adjusted a certain amount. I don't know if this is for emssions reasons or to protect shade tree mechanics like myself from throwing the adjustments really far out of whack.
As I'm putting it all back together, the c-clip that holds the clutch drum to the shaft when flying and I never heard where it landed. Grrr! I was able to get the saw running, but couldn't really test it. Once the saw got running, the clutch expands and then hits the body of the saw. Instead of breaking something, I shut it down. I'll hit the hardware store today and grab a c-clip.
