Homeowner's insurance
mtnbiker727
341
PA
We finally bought a house here in Pennsylvania (we've been renting), and I was told by my long-time insurance broker that pellet heat is not an "acceptable" primary method of heating a home. He said it needs to be thermostat controlled and have a supply for at least several days. I told him I was buying a pellet boiler with a 14 bushel hopper, and he said that's not good enough. I finally told him I would leave the oil hot air furnace in, but I hate hot air don't want that thing taking up space in my basement.
Erie won't insure the house because it has 3 tab shingles (new rule).
I've also read that some companies won't allow a biomass boiler and fuel to be stored inside the house because of fire risk.
Does anyone have an insurance company that I should try?
AFAIK, most insurance companies require a primary heating system that can run while no one is there (oil, gas, electric). I get it, especially in cold climates where frozen pipes could cause damage.
Same here in Ontario, no automatic system, no insurance.
I heat mainly with wood, but have a wood/ propane combination
furnace wooks well have not bought any propane in 3 years, and the tanks are still at 45% full
Here in PEI, my house had an oil boiler. It was removed before I bought and heat pumps installed along with electric heaters. My insurance did not call that out. To me it is not as reliable as oil, as heat pumps don't work well at -10C and below and you need utility power. You need power for the electric heaters too, but you could use a generator. Maybe a heat pump and/or some electric heaters would satisfy the OP's insurance company and be a good choice regardless.
hadn't heard about a 3 tab rule, but any roof that is 20 years old, ins co won't even quote , type not withstanding ( includes clay tile and steel
I was not aware of a 3 tab rule so I looked it up. I put on a new roof last year. Insurance did not ask me about it. I put on good quality ones with the raised tabs. Plus here they tar each one due to wind.
Quote:
Yes, they're obsolete compared to dimensional shingles. Insurance companies are upgrading roofs to dimensional as they won't insure a 3 tab roof in some areas due to winds. Tabs blow off too many times. Roofing companies and insurance companies are phasing out 3 tab shingles. Just not a good product anymore.
Just keep checking around. You may be able to have a stipulation that leaves the roof out if needed. Just a thought. We have had only wood heat for many years, and they never said a word. Not sure what they would say now, since nobody has asked any questions in over 15 years.
I’d put in a min split. Are they going to ask for your manual J and see if it’s sized appropriately?
Reactions: Isaac Carlson
