House smells like smoke in mid summer.
PalletteBurner
1
Saint Louis, MO
Bought this house last year and burned wood all winter. Now that it is hot and humid, the house smells of smoke though I have not had a fire in months.
Do I need one of those sealing chimmney caps?
It's a brick fireplace (about 22 years old) with a High Valley insert.
You should probably get your chimney professionally cleaned, and get either a sealing cap or something that will seal inside the flue. Take a look at this thread: https://www.hearth.com/talk/threads/39041/
I cut a round plug out of 6" thick foam rubber, and made it a little bigger in diameter than the pipe that passes through the thimble into the chimney. I can reach in my cleanout door outside and install it in the thimble. If I push it into the pipe a little bit so it does not stick out into the chimney, I can leave it in when I brush the chimney, too. No smoke smell, no dust when brushing, no bees. :cheese:
I just need to be sure I remember to take it out at the start of the burning season! :)
