I keep fighting a downdraft with a 3 flue exterior 35'+ tall masonry chimney. I know it's not ideal to have an outside chimney but it was built after I bought the house. One 8x8 clay flue serves the oil boiler in the basement, one 8x12 serves a wood boiler in the basement and another 8x12 serves a woodstove on the main floor of the house. Clay flues were wrapped with roxul and I have 1 S.S. cap covering all 3 flues (w/ SS baffles between exiting flues).
House is a 2001 built 2-story 2600 S.F. with a full basement. Center stairwell, Hydro-air for HVAC. House has vents in the floor (first floor) & vents in the ceiling for the 2nd floor. 2nd floor has bathroom vents, a sealed attic hatch, & a couple insulated recessed light fixtures. Typical 2x construction, 5/8" plaster drywall, tyvec wrapped & vinyl sided. Vinyl windows & doors.
First scenario.... Wood stove going on the main floor, smoke smell omitting from the openings (Barometric Damper primarily) from the wood boiler (not in operation) in the basement. So, the cold flue serving the wood boiler is pulling smoke down from the adjacent flue serving the wood stove. This would leave me to believe that my house is relatively air tight. That the wood stove on the main floor is pulling combustion air from the basement via the wood boilers baro.
Second scenario... Very cold outside and wood boiler is in operation. After 3-4 days of continuously using the WB, I started noticing a smoke smell omitting from the oil boilers baro. I ended up cracking a basement window slightly and the smoke smell became less severe.
Finally, we have had 2 days with weather above 40. Sunday morning, I shut the WB down to do a cleaning & closed the window in the basement. 2 hours later, I decided to light a fire in the wood stove. I normally warm the stovepipe a little with a torch but to my dismay, it had such a downdraft that the flame was "mushrooming" across the torch head. The stovepipe was unusually colder than normal. I ended up re-opening the basement window, opening the cellar door and waiting 15 minutes. Sure enough, I was able to get it going. This to me, would indicate that the house was creating a strong stack effect (leaky 2nd floor). But could it have been possible that the wood boiler (below) was sucking so much air that it was also pulling through the wood stove on the main floor? This would lead me to believe that the house is relatively tight.
