How hard is it???
Swedishchef
3,275
Inuvik, Northwest Territories
Hey guys
In the coming 2-3 months I plan on installing a Class A Supervent chimney in my new garage. I have 23 feet of chimney as well as the T(and plug). However, I don't have a support brackets or a rain cap. All chimney was brand new and I got it all for $500 (for once the "luck" Gods were looking down at me!!! They seem to pass by me often and this time made a pit stop!!). I only need about 12 feet of Class A chimney to get well above my garage roof.
So I think I am missing: wall thimble, couple of 15 degree elbows (avoid going through the overhang of the roof), 2 wall bands, wall support and a rain cap. Am I missing something?
How hard is it to install this setup??? I cringe at the idea of trying it however I am fairly handy, I just built my garage. I think it is the fact that it has to do with fire....
Thanks in advance
Andrew
It's not too hard, the big thing is you have to get the clearances right. Probably the hardest part is installing the wall thimble, as it has to be framed into the wall with specific clearances. If you don't fall between a pair of wall studs, you have some finangling to to. I would try and avoid using offsets if you can, they are very expensive and you cannot look through your pipe. Go through the eave and install a roof flashing and storm collar. Also, a 12' run may not draft very good. I would consider going up at least 14' to 16' and getting a roof brace for the pipe. Very easy to do IMHO. But if you got all that pipe for 500 bucks, you got a hell of a deal.
" I think it is the fact that it has to do with fire...."
Hint: don't light the fire until after you've finished installing the chimney. ==c
Reactions: milleo
Scotty: I think I may listen to your advice. I just remembered that the eaves I need to go through is simply on the gable end. I simply need to cut a hole and put the flashing. It will save some time and a bit of $. I can always add another piece for proper draft. Heck, I have it anyway!
Yes, I did get a great deal. $1000 worth of chimney for $500.
Any recommended websites for SUpervent parts?
Andrew
Here's a link to a flashing that I found....this one fits 0/12 to 6/12 pitch roofs....
http://www.lowes.com/pd_271993-8517...perVent 6" x 24" Stainless Steel Chimney Pipe
Here's one that fits 6/12 to 12/12 pitch roofs...
http://www.lowes.com/pd_35015-85178...perVent 6" x 30" Stainless Steel Chimney Pipe
Here's the base that the tee sits on, you need this piece if you do not have it....
http://www.bing.com/shopping/superp...ipe&lpf=0&lpq=superpro+pipe&FORM=EGCA&lppc=16
Here's the wall bands (to fasten the pipe to your outer wall and allow a 2" airspace.....
http://www.bing.com/shopping/6-supe...pe&lpp=10&lppc=16&lpq=superpro+pipe&FORM=EGCA
Here is the rain cap...
(broken link removed)
I'm not saying these are the best deals out there, but this will give you some cross-reference and part numbers to look elsewhere. Superpro and Supervent pipes are interchangeable parts, each style will fit the other. Shop around. Hope this helps out a little.
