How much extra air do you think ?
Trevor Tahclep
313
Quebec, Canada
How much extra air do you think a 1/2 inch boost air hole is supplying to a stove burn and how does it affect your stove ?
It would depend on the velocity.
I have two 1/4” boost air holes in my F45 and it effects my setup greatly. Burns much better with them plugged.
With a full load that on the edge of an over fire I’m guessing 150 degrees. Just a guess.
It depends entirely upon your draft.
Reactions: ABMax24
Treat it as a simple orfice. If you know the diameter of the hole and the pressure differential across it you can roughly calculate the flow rate.
Reactions: Winterpeger
