I'm using duravent pellet Pro. It says to silicone the appliance adapter and if I do and then assemble the system it doesn't seem like there will be any way to disconnect it from the chimney system without breaking the silicone seal.
It's a corner installation and I would like to be able to pull the stove forward for maintenance.
Is there any way to get them apart while everything is together if that joint is silicone? Can you get away with just putting a little silver tape around it and a pipe clamp?
Should I just order the quick release adapter from duravent?
![[Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance? [Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance?](https://www.hearth.com/talk/data/attachments/274/274470-5bb351bb4e4ddb2169fad94c39bbd815.jpg?hash=3EMBcBacmq)
![[Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance? [Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance?](https://www.hearth.com/talk/data/attachments/274/274518-0a9f428edc6e059ff2b7071517a23dac.jpg?hash=R7wdzTznhB)
![[Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance? [Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance?](https://www.hearth.com/talk/data/attachments/274/274520-06d204bbbf2a2814f664bdad441222ef.jpg?hash=Uz4b2zd9_P)
![[Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance? [Hearth.com] How to attach pellet pipe, so that you can pull the stove out for maintenance?](https://www.hearth.com/talk/data/attachments/274/274521-d080e2c1d2dd659422f312b377251ec4.jpg?hash=xs67FgGAfA)
