I just bought a used wood stove in decent condition for my three car garage. The garage is insulated but not finished.
The stove is fine for what I need. Little rust on the outside but otherwise good condition. There is one fire brick inside that is broken that I will replace.
Can anyone offer some material requirements for me? I'd like to stay within New Hampshire code.
The stove exits with a 6-in fitting on top. I'll be going straight up through one uninsulated floor and out the insulated roof above that floor. Total run will probably be around 20 ft. No elbows or bends.
What do I need to be looking for as far as pipe goes? I obviously have a good deal of time before next winter so I'm going to keep my eyes out for any sort of deal.
There will be an insulated, non-sheetrockedn wall behind the stove but not on the sides (the walls on the sides are at least 8' away. How far from the wall should I be, and do I need to put any type of protective backer board on the wall.
The floor is concrete. How far off the floor should I raise the stove? Currently, the legs keep the stove about 6 in off the ground.
