How to loosen stuck screws
suprz
219
Rhode island
Well, now that my stove is out of the basement and i can get to all of it, i would like to replace the gaskets, and especially the gasket on the glass. However there are two screws 1 on each side that hold brackets that hold the glass in place, and they are stuck. Plus it would look as if someone tried once before because the screws look a bit "worn" . should i soak them with PB Blaster or something else to see if they free up? What do you guys do to get these out (without drilling and tapping)
Penetrating oil such as PB Blaster or liquid wrench and one of these impact drivers:
[Hearth.com] How to loosen stuck screws
Reactions: pen
Heat the screws with a hair dryer, then spray them with Seafoam. Let them sit over night. You want to give the Seafoam time to wick into the threads. Stuff that wouldn't budge, I would spray again and try 30 minutes later ,,, it loosened things right up.
Worse case senario, have someone tig weld a nut to the screws.
I usually use PB blaster as a first resort for loosening. Kroil is my go to after PB doesn't work. Between that and heat I've been able to get most things. The manual impact wrench is a great idea.
Matt
Glass gaskets usually last a long time, they are not a wearing part. But if one must replace them, after soaking in kroil or other penetrating solvent oil, see if you can get a solid bite on the screwhead with a small pair of vice grips. Or just drill the sucker out and re-tap.
Lots of good info is being suggested. I would like to add that I have had a lot of luck cursing at stuck screws before, during, and after the process of of loosening screws. My success rate with the cursing method is surprisingly high.
Using a hammer on the impact, I'd be leery of the door glass cracking from the shock.
Agreed. Though 'd also worry about applying heat locally to cast iron (if the stove is cast iron). Unequal heating of cast iron can create cracks.
This reminds me though, I always apply anti-seize compound to fastener threads on things likely to seize up.
Good point, I use the copper stuff myself. Of course those wind up being the screws you never have to touch again;lol
One thing I didn't see mentioned is to clean around the screw as good as you can with a sharp screwdriver or chisel, so the penetrant has a fighting chance of getting in there.
If you have to drill into the screw because the head is stripped, try an "EZout" (broken link removed to http://www.brokentap.com/easy-outs.html). You may not have to drill it out and tap for a larger screw. Pretty handy to have a set around anyway.
I had an old timer tell me that they use to get frozen exhaust manifold studs out by heating the stud and touching or melting a candle into the threads. Was it an old beeswax candle,,, I have no idea?
(broken link removed to http://search.yahoo.com/r/_ylt=A0oG7hP7aJFQOTAAx6xXNyoA;_ylu=X3oDMTE0Y2tqbThzBHNlYwNzcgRwb3MDMgRjb2xvA2FjMgR2dGlkA0FDQlkwMl85OA--/SIG=12hlgd7ij/EXP=1351735675/**http%3a//suite101.com/article/how-to-remove-a-rusty-bolt-a95912)
How to Remove a Rusty Bolt Get a Frozen or Rusted Bolt ... Melted Candle Wax on a Hot Bolt. ... The goal is to keep from chewing up or round off the head of the bolt.
suite101.com/article/how-to-remove-a-rusty-bolt-a95912 - (broken link removed to http://search.yahoo.com/r/_ylt=A0oG7hP7aJFQOTAAyKxXNyoA/SIG=1a12ndlks/EXP=1351735675/**http%3a//74.6.238.254/search/srpcache%3fei=UTF-8%26p=candle%2bfrees%2bup%2bfrozen%2bbolts%26fr=yfp-t-701%26u=http%3a//cc.bingj.com/cache.aspx%3fq=candle%2bfrees%2bup%2bfrozen%2bbolts%26d=4511936952272556%26mkt=en-US%26setlang=en-US%26w=cee28259,690d5255%26icp=1%26.intl=us%26sig=pEz0puBdCGJXZ6T2KGnRBA--)
Cobalt left handed drill bits do wonders. While drilling counterclockwise the bit vibrate the screw and it usually loosens up.
If you end up having to drill it out I'd recommend you use a left-handed drill bit. In many cases the use of the left handed bit alone is enough to remove the screw.
Edit: peakbagger beat me to this by about 30 secs. I didn't see his post before posting mine.
