How to remove baffle from hearthstone Mansfield
remove the angle iron resting on top. thing should come right out.
Just out of curiosity look and see if there are any cotter pins through the tubes and through the baffle. Look up inside at the tubes. I know they use cotter pins on the Equinox. If not it's just cemented in on the edges. You may have to break it out.
On second thought, I found this diagram. It looks like you also have the blanket to deal with but I don't see any fasteners.
[Hearth.com] How to remove baffle from hearthstone Mansfield
(broken link removed)
Here's the tech sheet from Hearthstone...
(broken link removed to http://www.hearthstonestoves.com/assets/files/document_library/3120-202.pdf)
HTH
oh yeah I forgot you must remove the secondarys. Angle iron is just resting in place. remove angle iron and blanket.
the baffle should be in 2 pieces if I remember correctly.
Thanks again guys sorry it to so long to get back to everyone that chimed in. Hopefully everyone has their stoves going. Mine is still not hooked up. Been slacking
Matt
