How to remove door on hII stove
motoman
4
Colorado
Hello
I am a new owner of a hearthstone HII and love it! I bought a replacement glass for the front door but I am uncertain on how to remove those two pins holding the door on? Do I just tap the pins out from the bottom? And then reverse to re install door? I just wanted to check in on how before I went pounding out a pin that I might not be able to re insert? Hopefully it's just that easy.
Thanks for any help
You might be able to lift the door off the hinge posts with the pins in place.
If you can't, just gently drive them out...
Reactions: valley ranch
