How to remove snapped off plenum clean-out cover screw in Quadrafire Classic Bay
sksmass
206
Western MA
I was cleaning my Quadrafire Classic Bay and managed to twist the head off of the screw holding one of the exhaust plenum clean-out covers (part 410-7910). The plate came off fine but the screw is still in the hole so now I can't affix the cover.
Three questions for the more experienced out there:
1) is there a trick to remove the remains of a bound screw? I have tried heating it with a torch and lubricating it with light oil. And vice grips. Should I just give up and drill it out and replace it with a larger self-tapping hex head screw?
2) if I can manage to get the screw out cleanly, what is the proper thread and pitch machine screw to replace it with? 8-32 or 10-32?
3) is there any way I can run the stove in the meantime by, for example, using ceramic magnets to affix the cover, or maybe jerry-rigging some heavy piece of metal to lean against and support the plenum cover from inside the firebox?
  • [Hearth.com] How to remove snapped off plenum clean-out cover screw in Quadrafire Classic Bay
If you can not get a hold of the broken screw, drill it out and tap it to whatever size you need. The new screw: you want a stainless steel screw
Reactions: Washed-Up
I'd be a little "gun shy" to use a stainless steel screw, especially since you just broke a screw. You'd have a real issue if you had to drill out the stainless screw. !!!
Tom
Penetrating oil and vice grips wouldn't budge it. So I just ended up dremmeling off the remains of the screw, trying to grind it flush, and then drilling a new hole slightly to the side of the old one. Then used a self-tapping 1/4 hex screw as a replacement. Seems like it'll be fine.
No, that's not the kind of product I have in my shop, or that is even stocked in my small-town hardware store.
For now I think I'll just endeavor to make sure to work the threads by unscrewing it a few times each burning season.
Some day when I go to a better hardware store I'll try find some high-temp anti-seize.
Auto part stores or HD should have it.
Tom
Reactions: ABusWrench
