My pellet stove is an insert with exhaust and inlet inliners all the way up to the chimney top. we didn't use it this year. I can feel strong draft from where it is. How can I stop the draft or make it lose less heat when it is not in use?
Touchepetemal said:you could always turn it on.........................................
its called a damper cut-off or damper plate. Use fire wool as an insulator not fiberglass and it should be 4 inches thickmrjohneel said:Stuff the area where your old fireplace damper is/was with insulation and then seal it with thin piece/s of sheet metal fashioned with holes so you can run your exhaust/air inlet pipes through it. That is, you're creating a damper of sorts that seals the space and you place insulation above it. Good luck.
lmei007 said:petemal said:you could always turn it on.........................................
Good idea.
how about summer? the hot air come in and condensate inside the stove body.
I am mainly concern the air (cold or warm) come in through the steel exhaust and air inlet pipes.
SmokeyTheBear said:If you have a easy to move insert and a quick disconnect, you can also plug both of the pipes. Just be certain to leave yourself a note where you can't miss it.
This will be a valid topic for us to disscuse.Weird tolienish figure said:Or get rid of it if you're not using it.
lmei007 said:This will be a valid topic for us to disscuse.Weird tolienish figure said:Or get rid of it if you're not using it.
I had a bone marrow transplant and cannot use my pellet insert for a year. Can I get detailed helpful information regarding how to stop the draft?you could always turn it on.........................................
As long as you have an outside air kit the stove is a closed loop. The draft is coming from the chimney, a 4-6 inch thick block off with Roxul should eliminate the draft. I would do 2 layers, a looser layer above a tightly packed around the pipes layer.I had a bone marrow transplant and cannot use my pellet insert for a year. Can I get detailed helpful information regarding how to stop the draft?
Thanks so much for the helpful information! That'll get me through the winter!As long as you have an outside air kit the stove is a closed loop. The draft is coming from the chimney, a 4-6 inch thick block off with Roxul should eliminate the draft. I would do 2 layers, a looser layer above a tightly packed around the pipes layer.
