From the manual"
So I can actually use ATF? The unit has hydraulic fluid in it, but I don't know if the dealer bled the pump yet which is self-bleeding so the manual says run the wedge 12 times with a full cycle and then check the hyd. fluid reservoir level and top off so I plan on doing this afterwork after picking up some hydraulic oil or ATF....
Jay
			3. Fill the reservoir tank with hydraulic fluid included with
this unit (if equipped) or approved fluids which include
Dexron® III / Mercon® III automatic transmission fluid,
a 10 Weight AW hydraulic oil or Pro-Mix™ AW-32
Hydraulic Oil.
Jay
