I built a 1200 SF apartment above my garage for my daughter and her family. I used ½ inch pex under the floor. The heat comes from the outdoor wood boiler water on the return to boiler run after it has gone thru my house by 2 closely spaced Ts on the 1” main loop. I have a mixing valve to keep the heat under the floor at 125 or less, it is a nice heat and I wish I had it in my house. This system has been working for 4-5 years now.
The problem is that I have 3 zones for them, each has it’s own pump drawing from a 1” into the ½ “ through a manifold. One of the pumps sometimes becomes air bound and free spins. Once when I was not home to shut it down it cooked the bearing. I replaced it and now the new one has become air bound already this year. I cannot understand why it gets air.
This zone only has 2 loops off the manifold, they heat the bath room then each drop down 10 feet to go thru a baseboard to give some heat to a hallway and a pool room we don’t use during the winter. The water goes back up and into a return line with a check valve.
I don’t understand the terms describing the power of the pump. It seems like the weight of the water going down 8 feet would equal the weight of the water being lifted back up the 8 feet to the return manifold. I’m afraid the pump is cavitating. I’m including some photos to try to help understand the layout of the system and problem.
I would like to understand the problem so I can find the fix. Any thoughts would be great!
