Ghettontheball said:burn the pellets & u get x heat via molecular agitation. does the thinness of the air make the diff or the humidity, or do the pellets produce less heat?stoveguy2esw said:Ghettontheball said:DUH, TOP OF STOVE IS STILL RADIATING AT CEILING pstove radiates into chamber where blower converts to convective & delivers sideways & towards floor like my 25 pdvc= i disagree but weigh the wood & pellets on your way. BTW wheres the specs?stoveguy2esw said:MountainStoveGuy said:stoveguy2esw" date="1253847560 said:here's a theory , not sure how much impact it has on your situation bro , but here it is.
in a higher altitude low humidity situation , radient heat (which heats up not only the air but the surrounding surfaces) is going to do what its going to do heat said surfaces. convective heat is supplying heat to the air , not to the surfaces , now since you are high and dry so to speak , there is less "air" going through the stove into the room , even the humidity in the air gets heated to some extent. so convection without as much substance to "convect" means a lesser transfer of energy per BTU released due to the method of transfer.
make sense????
if im right , you would realise much more result from the radience of a woodstove and less from strictly convective heat , therefore the lesser performance. just a stab in the dark mind you , but it makes sense to me though i havent studied it out fully.
That is really really really good. I tell you i learn something new here everyday. I have never tried to heat in a humid environment, so i would have no basis to compare to. It is so dry where i live, you can leave a bag of potato chips on the counter open, for two weeks, and they do not get stale. Dont ask me how i know :roll: You add that to the altitude, (9000+ feet) and that could be a bad combination for a pure convection stove.
give the credit to POOK , had he not started on that tangent about mold bringing you to mention the "high desert" thing , i wouldnt have thought about it that way, theory was strictly off the top of my head , i dunno if someone has published similar though i might look around for it sometime. guess you caught the gist of what i was thinking anyway. BTW im flattered by your reply.i consider you to be a very smart guy, so im taking that as a complement if ya dont mind ;-)
his model is not as good a radiator as the pdvc due to the pdvc having a lot of the firebox exposed to outside, its still a great stove though more of a "true convective" design so your stove having that one sheet of steel between the fire and the room gives off more radience. also , you are in a more humid more air dense area than he is so there is more "stuff" coming out the vent at your house than his. the more density in the air the more transfer you get due to more molecules to reatain and carry heat, simply more molecular surface area in denser air. at least thats the gist of my thought on it. as for spec's i'll check again , but remember corie is a busy lad with a lot on his plate, he likely has forgotten my request.
the top of the woodstove still radiates at the ceiling,eh?
exactly right in one part , molecular agitation , or retainment and release of energy , the difference is the delivery system , pellets pound for pound contain the same base storage of energy as log wood does roughly 8500 BTu per LB remember pellets are still just wood so the same thermal energy released from consuming a 1 lb block of wood is released by consuming 1 lb of wood pellets. the diference with pellet stoves is the energy is channeled and released under different methods than wood (or log) stoves utilize. the more surface area that comes close enough to the radient heat inside the exchangers of a pelet stove , the more heat is absorbed per cubic measure of air then moved into the open airspace of the room. with a log stove , the whole skin of the stove is the heat exchanger so more molecules come into contact or close proximity to absorb heat also the heat exchangers in a pellet stove are internal for the most part so radience is trapped somewhat by the outer shell of the stove with wood it transfers through directly into a room which is why if you think about it , a wall protector works as it does , and why you have to keep an opening at the bottom, heat radiates onto the wall surface transfers through and into the airspace , but the resulting updraft from the heated air in the space allows heat to be carried out the top and the resulting vacuum pulls more cold air in to absorb the "next " heat in a constant moving current.
and to think i used to hate physics somewhere out there my high school teacher is smiling
There is a 3 week learning curve in my opinion, even if you have boat loads of knowledge (which I know you do). Its the actual application of that knowledge, in real world, that takes time IMHO. The laws of entropy are extremely complex and are hard to try to decifer, but in the end, I think you just aren't conveying to the machine what you'd like, in a language that it can understand. If you are in room temp the stove attempts to heat until the room temp probe is satisfied, that is all. It cares not for your bedroom of your pantry, just the probe. Stove temp will dictate to the stove to burn pellets at a constant rate, and therefore constant even output of heat. You should find this more to your liking. One you have established a stabile temp and your house becomes a thermal mass, you can then switch to the room temp if you so desire and hopefully you will find that it is also, more to your liking. I'm a huge fan of the stove temp, and very rarely (read never, unless told to do so) use the room temp mode. ONce you estabnlish what setting (1-7) works best, you may only need to tweak it slightly during different times of the day, or very different outside temps. PS- Make sure your feed adjuster is set to 4-4.5, no joke.
