I need a router bit
30WCF
1,412
North Carolina
It needs to be reversed from this one but I can’t seem to find one.
It fits my wall boards, and I could cut the tongue out of the excess part of the longer sweeping area, and it would be a darn near exact match. EXCEPT, it’s oriented the wrong way.
If I just move the design to the other side of the board, I can’t trim off the excess sweep, and the profiles don’t match and it would be about 3/8” wider than its neighbors.
[Hearth.com] I need a router bit[Hearth.com] I need a router bit[Hearth.com] I need a router bit[Hearth.com] I need a router bit[Hearth.com] I need a router bit
Reactions: Whitenuckler
That is interesting. I have a router, but never ran into this issue. I wonder how they are made? Can you take one apart? I guess you already thought through the upside down mounting ect and that is a no go.
Reactions: 30WCF
This seems to be a one piece. The tongue and groove ones you can take apart. This one is solid.
I could strip out 1-3/4” sections and router that, then make both sides of the narrow, decorative strip male, and have the wide blanks be female on both sides. Lotta work and lotta extra joints.
Can you rout a piece and then join another to it?
You can get custom bits made for shapers and routers, but that’s expensive.
If you know who made it, maybe they have the opposite profile or wouldn’t be against making one.
You can get custom buts made for shapers and routers, but that’s expensive.
Thats why I’m thinking now. Make a narrow strip and mill it out to be male on both ends and join it to the flats.
It’s an Amazon special that looks to have lots of different brands selling the same profile and paint colors with different names on it.
This particular one is branded WSOOX. Pretty sure I know where that gibberish was originated.
If you're just doing a few pieces, I would mill the edge of a board with the bit you have, then rip off the molding and join it back the other way. A bit more work to setup but shouldn't be too hard.
If you need to do a lot, bring a piece of the original trim to your local lumber mill and ask if they can identify the profile or perhaps make a custom bit from your sample.
Reactions: 30WCF
I just went with a different bit for now. I doubt anyone who doesn’t know, will know. I had to fill the void. I may try milling some and reversing the design later.
This is just with the primer. It’s got a 5/8” tongue and groove, so it’s locked in.
