I need help identifying Vermont Castings RDVODRF radiance gas stove
Goodtobedead
5
Vermont
Just acquired this stove and need to get some parts, but I can't seem to find the exact model I have. This is my rating plate. The RDVOD I have a firm handle on. If I follow the way VC does things then my model should be a 2514. Yet that number doesn't exist. I would be grateful for any help
  • [Hearth.com] I need help identifying Vermont Castings RDVODRF radiance gas stove
this is what I am asking I guess . Here is a manual for rdvod: So I marked the model in blue. what does the things in yellow mean
Contact your local VC Dealer. They should have the info you need. You need an owner’s manual that is specified for that unit serial number.
Call Vic at Best Fire Hearth & Patio in Troy Ny (518) 687-2387 he should be able to tell you where to find what you need
I recently purchased an old Vermont Castings Radiance but haven't picked it up yet. Trying to figure out what model mine is before I get it to know if I'll be able to find replacement parts for the guts if I need to do so. DAKSY mentioned calling Vic at Best Fire Hearth & Patio in Troy Ny, did you try him, if so, did he get you the info you needed? I can't find a model online that shows the top with what appears to be an exhaust only hole. Pic attached below. Does yours look like that by any chance?
