Check out this guy. He's a chainsaw carver from Vermont named Barre Pinske, and he's trying to carve his way out of debt in a month. To do that, he has to carve $30,000 worth of bears in 30 days. He has a live feed going and has gotten 7 huge bears done since he began on October 31. Here is a link to his feed. Wonder how long he'll actually go.
http://www.ustream.tv/channel/barre-pinske-studio
He is using a Stanley CS05 hydraulic chain saw with a 7.5 HP hydraulic power unit designed and built by his dad. These are the saws often used in buckets trucks by tree trimmers and utility workers. Hydraulics are what power those huge wood processors that cut through 20" logs in a few seconds. They are near-zero maintenance tools of simple design and incredible power.
The use of hydraulics to power the saw makes for a tool that has all the power of a 120cc gas powered chainsaw at 1/3 of the weight. Plus, all of the torque is always available at any chain speed, so you can just feather the trigger and still not bog down in the cut. Kickback is all but eliminated because of the lack of a massive flywheel generating rotational forces, and due to the fact that the thing stops instantly whenever the tip gets bound or the instant you let off the trigger. No brake required, it's just a function of how the saw works.
No gas or oil to add (the chain oil is supplied by the hydraulic fluid itself), no tricky starting, no warm up, no periodic tune-ups or rebuilding, very little noise and no motor vibration at all. Cuts like a light saber. Anything bad to say about it?
$4238.50
And it's kinda hard to carry through the woods.
Anyway, check this guy out, he's a madman. Carves in his bare feet and shorts in the summer, no other PPE in sight.
Stanley’s hydraulic chain saws offer the highest power-to-weight ratio of any chain saw on the market today.
Hydraulic power doesn’t require a flywheel to smooth power pulses so there is no chain coasting when you release the trigger.
Kickback is also reduced without the centrifugal force from the flywheel used on gas driven saws. Features a floating rim sprocket for longer wear and easy replacement.
$4238.50
