ID this wood please...
JamesGuido
328
Home of the Brewers
found many pieces of this mixed in with my "All Oak Wood"
I like it, it's heavy, seems to burn very long, like oak...
I'm not complaining, never will. But i haven't an idea as to what it is.
Do You?
Thank you for your help & time!
[Hearth.com] ID this wood please...
Reactions: patrickk222
Also guess hickory
Reactions: JamesGuido
Hickory, mostly debarked. A little hard to process but it's a great burning wood!
That’s it! I’ll set aside a few with the higher mc for the smoker
I keep the scraps from when I split for my smoker. Have cut trees down and given to a friend with a commercial smoker. Can't beat the smell of burning hickory! It will pop in the stove and you have to be careful in a fireplace as it will throw embers out. Trees are pretty but the nuts are huge as they have a big hull like a black walnut. I've had them break a windshield when someone parked under one.
Hickory will sometimes have a darker center like that..
stringy and hell to split with an ax?
i had a bunch of wood that looked like the OP’s first picture this year, but figured they were some kind of birch. i see the occasional shagbark on my walks…
It's dense when wet. Dulls chains faster than most wood, and need a sharp chain to cut. Splitting I have only done with a machine which I would say doesn't load more than oak. Upside is the tree is usually quite straight until the very top. Very high BTU content and good coaling, don't pass it up.
