Ideal spot for damper
bruh44
29
North Carolina
I've got a 25-30 foot chimney that's 6" and lined. It goes through a large masonry chimney that I'm not getting into in the middle anyplace. The only options are at the bottom right behind the stove. This section is parallel to the ground for about one foot before it makes a 90 degree angle up the main chimney. The other option is at the top of the chimney. Both would be difficult to manipulate. No clue how I would manipulate one on top of the house. The one behind the stove is in a tough spot I would have to try to manipulate with a fire poker unless there is a damper with a longer mechanical arm I could set up.
Any ideas?
Any ideas?
It can't be at the top so which ever of the other 2 options will be easiest to access will be best
I haven't ever seen any off the shelf dampers with a pull rod, but as long as nothing was in the way of a straight pull, it probably wouldn't be difficult to fab something.
Awkward reaching around a hot stove isn't so safe. I have an awkward bypass lever on one of my stoves, and I have had the burns to prove my theory!
