I'm concerned that the new people are either not using their stoves right or making too early of an assessment of the stove.
It is not winter yet
!! When the outdoor temperature is 40 or 50 degrees, a tiny fire for a short time should be all you need. Don't try to burn up all your fuel before winter gets here.
I'm also worried that people are leaving the drafts open too far and too long. The stove top temperature isn't raising much so they leave the drafts open. Wrong! Close that thing some and some of that heat will stay in the stove instead of going up the chimney. And don't leave that stove if your draft is open 3/4 or full, or even at 1/2. It can get hot fast. These stoves are designed so that you can close the draft more to keep the heat in the house. For example, ours has settings of 1 though 4. We found that even at 1 it is too much draft once the fire is going. We have it barely open at all and in the winter when we fill the firebox we'll get 550 degree stove top temperature very easily.
I also worry about those who buy the stove and install it, then get the firewood. Wrong! Should have got the wood first. Also people have to understand the difference in how that stove works with different type of wood. Burn some dry soft maple, or some dry oak and there is a difference. The maple will burn hotter and faster. The oak will hold the fire longer. Now compare poplar or pine vs. oak and the difference is greater.
Now try burning some half seasoned wood vs good seasoned wood. Huge difference! Now try burning small splits vs. larger splits. Or what about that wood that you don't even have to split? There is a learning curve, but please don't think you will learn much when the outdoor temperature is above freezing.
Finally, please don't forget to check that chimney at least once per month. The reason is that most do not have good seasoned fuel and that will cause creosote. Also, those who insist in filling the firebox at this time of the year have to close the drafts too much and the smoke and/or gasses in the chimney cools too quickly and there is the creosote. Let's not have a bunch of chimney fires, please!
I don't know if I've worded this thread the best or even completely what is on my mind but this gives you some idea. I've re-typed it a couple of times but this time it is done. Now tear into me if you must but it is my hope that we can help a few people.
!! When the outdoor temperature is 40 or 50 degrees, a tiny fire for a short time should be all you need. Don't try to burn up all your fuel before winter gets here.I'm also worried that people are leaving the drafts open too far and too long. The stove top temperature isn't raising much so they leave the drafts open. Wrong! Close that thing some and some of that heat will stay in the stove instead of going up the chimney. And don't leave that stove if your draft is open 3/4 or full, or even at 1/2. It can get hot fast. These stoves are designed so that you can close the draft more to keep the heat in the house. For example, ours has settings of 1 though 4. We found that even at 1 it is too much draft once the fire is going. We have it barely open at all and in the winter when we fill the firebox we'll get 550 degree stove top temperature very easily.
