I'm sure this topic has been discussed many, many times. I just purchased and installed a Summers Heat 1500 model. We have an older iron enclosed fireplace in our living room, - it's not quite a wood burning stove, but similar. We have very poor access to wood. We decided to place the pellet stove in our kitchen.
Naturally we knew it would be much warmer in our kitchen and since the stairs to our 2nd floor come off the kitchen, we also knew our second floor would get some nice heat. The second floor is essentially one big room, which is our bedroom.
Our problem seems to be getting the airflow into the other rooms of our home. The house is built on a crawl space and is only two stories. Built around 1950. The crawlspace gets very cold and the first few inches closest to the floor can be very chilly when it's cold out.
In the below thumbnail, you can basically see how our place is set-up.
![[Hearth.com] Improving air circulation [Hearth.com] Improving air circulation](https://www.hearth.com/talk/data/attachments/116/116777-04410ab9771b82116dd8b894a680115f.jpg?hash=eSFvqnT8Ce)
Please forgive my poor adobe illustrator drawing, the fireplace is basically left of center in the home with it's chimney running up the right side of that black rectangle (which would be right in the middle). The fireplaces' opening faces the living room.
We really didn't have too many options when we decided to put the pellet stove in. So it was decided it would go in the kitchen with the vent going outside under the stairs going up.
Even when we have just used our fireplace, that heat only heats up the living room. Every room seems so closed off from the others. What I'm trying to figure out is how to get the heat from our pellet stove flowing into these other rooms.
To give you some idea of the drastic change in temperature, it can be 70° in our kitchen with the pellet stove going at around 5 or 6, but as soon as you walk through the opening to our living room (the next room) you can feel a drastic drop in temperature. The other rooms will only get up to 60° - 62° nearly a 10 degree drop from the adjacent room.
Just trying to get some advice or ideas on how or what to do to get the heat flowing better into these other rooms. While it's great that the heat does go upstairs, we basically just sleep up there. Would installing registers going from the kitchen into the bathroom and bathroom into the right side rooms help? I'm thinking it might, but not sure. Before we put the stove in, the kitchen was one of the colder rooms, due to a very small amount of baseboard pipe running in there. Now it's the hottest, but it's all trapped in there.
