Hello all;
I’ve been lurking around this board for a few months looking for some ideas for our hearth. I must say I have found a ton of info.
First, here’s a little history of my situation.
My wife and I are in the middle of construction for our new house. We’re doing 90% of the work ourselves. I can tell you that it’s a ton of work! But it’s worth it. I’ll be very proud of the completed project when it’s finished.
Our plan is to build the foundation and first floor decking, put a roof over the decking and finish out the rest of the foundation. We want to live in the foundation for a few years and then build the rest of the house. So far, we have the foundation up and first floor decking finished with a rubber roof. The chimney is up as well. I have a 2-flue masonry chimney coming out of the foundation; one for the oil boiler and one for a wood stove. I’m planning to install a high efficiency fireplace in the living room when we get to the upstairs.
My questions are:
1. I have an 8x8 flue liner for the wood stove already built. Would I be ok running a stove with a 6” stove pipe into the 8x8 flue? Or will I still need to line it with 6” pipe? The entire chimney is on the inside of the house and will have about 10’ of height. The chimney draws extremely well from what I tested so far.
2. I’m a little confused about how to size my stove. I’d like a stove that will provide ample space heating for the whole foundation of about 1200sf. Ample would mean the boiler wouldn’t need to run while the stove is burning. It’s mostly an open floor plan with 2 bedrooms and 9’ ceiling. Should I buy a stove sized for the open living space or the entire floor? I’m just going to rely on a blower to move the heat around and would leave the doors open to the bedrooms. I don’t want to be driven from the area where the stove is because it’s in the main living area of the finished foundation.
Thanks in advance for any help.
Hunter819
My questions are:
Hunter819
