Q&A Information on waterstoves or outdoor wood boilers
QandA
Staff member
0
Question:
I'm looking for a stove installed outside the house. This stove heats water which is then sent to the house via pipes and into an exchanger which heats the house. It could also be use to heat workshop- garage or barn. If aware of this- or similar- system- please reply. :-)
Answer:
There are a lot of companies that make these "waterstoves" .but we have found them to be relatively inefficient.
I feel that if you are going to burn a lot of wood- you should burn it cleanly. Check out the boilers at: http://www.woodboilers.com , they have some which are quite clean.
Link: HS Tarm Boilers
