So at this point, I'm hauling more or less the last of my wood from the drying area to the wood shed. There might be a little left after this, but not much. I'm here to put forth some thoughts, and see what anyone has to comment...
NEVER again, at least on purpose, will I try to acquire oak. That stuff is the most horrible stuff to deal with. Specifically, it rots quick. The bark on my +-3 YO stuff is turning into the most messy crap. What with the bugs that have eaten it, and the water it holds...It's just insane. Maple that has been in the same stack under the same conditions is not nearly so nasty. But what are you to do? Oak takes a long time to dry...it also burns crappy in my stove, leaving a fairly solid bed of clinkers on the bottom that don't fall through the grate. AND, oak tends to NOT leave coals for the morning, unlike maple.
OK, part of the problem with the oak is that it wasn't necessarily covered while drying. In the fall, leaves get into the stacks, and rot down, holding water, which makes this issue worse. I've come to the conclusion that it may be worth it to top cover EVERYTHING, and wrap it completely (shrink wrap?) when the leaves are falling. In my experience, top-covered-from-day-one wood dries way faster, and stays in much better condition. It may look white, but the bark is still tight in most cases, and it burns easily.
You know, having several years worth of wood may not be the answer. It gets messy, it takes up a huge amount of space, and I tend to forget what wood I stacked when. If the oak is removed from the equation and everything is top covered from day one, I bet I can get nicely seasoned wood in 24 months. Granted, burning 4 cord a year, that's still 8 cord sitting there at all times, but it's less than we've had in the past.
Here is my preference for species, starting with what I would most rather burn;
Maple, any kind
Black birch
Ash
Hickory
Cherry
Poplar
Pine
Horse Sh!t
Oak
I may or may not put ash & hickory higher, I have no experience with it. This year, I do have a stove-full or 2 of ash, so we'll see...
I am thinking at this point that I'd rather have a pellet stove.
Maple, any kind
Black birch
Ash
Hickory
Cherry
Poplar
Pine
Horse Sh!t
Oak
