2/27/09 Just an update on my little Lopi Answer Insert after about 5 months of burning...if anyone is looking at purchasing a small insert and not burning 24/7
Well, I have to say I am pretty pleased.....had some oil delivered today (1st since 12/3 and we took about 180 gallons.....heat hot water with it too)
Been keeping track of oil useage, and we have used about 39-40% less than last year for the exact same time period, and temps have been much colder than last year here in New England. (We have a family of 5)
Some thoughts updates:
Temperature: The lower level of the house is consistantly at 70-72 degress with the stove running, and before we would keep the thermo at 64 degrees...cant imagine how much oil I would have burned with the thermo set at 70-72 degrees . Upper floor gets to 66-67 after a full day or burning, so really no need to turn on the heat..programable thermo kicks on upstairs at 63 degrees. ...My problem now, is that when I don't have the stove running my wifes internal temperature module has shifted from 64 to like 68 on the themostat, so on days we don't fire it up, we are using more oil
Wood Useage - Pretty much ran out of my good stash of oak and maple, and I am now on to the maple that has been cut/split about 7-8 months. Burning from say 6am to 6-7pm I have used about 1 1/2 cords...this would be three times per week, and the weekends....so figure I am burning 12 hours/day for 5 days
Wood sizes - The insert has a small firebox, so it does better with several small splits....been using splits sizes about the size of a Popeye forearm, and usually 3-4 will burn good for 3 hours or so. When he had the ice storm and no power, I did pack it to the gills a few times, and we squeaked out about 5 1/2 hours with a stack of red oak - seasonsed for 2 years. (12 hours is not even close to realistic...but I had planned on 5-6 max when I bought it....also, I consider a "burn" to be temps starting at 550 or so, and then dropping down to 300 before reloading)
Blower - It seems to work well, but I have been getting this annoying rattle at med to higher speeds.....I down think it is the blower per se, but a vibration between the top of the blower, and the bottom of the insert....washer/shims work sometimes, but I haven't had the time to take it apart yet. Might just need a little "persuasion" on my part.
Overall cost: Appx $3200 including a full liner and the blower.
Hope this might help some folks on their decision....feel free to pm me with any specific ???'s
Thanks for reading.
(Older post)
Hi All,
I figured I would post of a review on our insert installed over the summer. I know that there is a review section on the site, but I always thought the reviews were a little "light". I thought a small review might help some of the newbies (including myself) on perhaps what to get for an insert.
House size is 1800 sq feet, with 900 on each floor. (Its your typical colonial that my wife and I vowed never to buy for lack of character...and here we are
We don't have cathedral ceilings, and the rear of the house is open from east/west. With the front rooms boxed up a bit.(Basically, not a real open floorplan)
I'm situated in North Central Massachusetts, with an elevation of apx 1000'....a few miles from Wa-wa- chusett!!
Ceiling height is 7 1/2 feet on the first floor, and 8 feet on the second. No big foyer/entryway...just a small hall in the middle with the stair in the middle as well.
Insert is located on the far end of the house, with an exterior chimney, appx 26' with a full liner.
We had a rather small fireplace, so we were limited on what we could fit as the back of the fireplace tapered greatly. Also, didn't want to have a large extension on to the hearth, so we went with the Lopi Answer Insert.
Its a pretty small insert, so I was a little worried that it wouldn't heat the house that well. So this week, we have had temps at 15-20 at night, and around 30 highs during the day, so I thought I would give it a run and see how it performed.
I work at home 3 days/week, so these are my burning days for now. Basically, I start it up around 6:00 am....after it is running nice with some small kindling, I put around 2 to 3 med sized splits at about 7:00am....let it get to about 500 and damper it back about 3/4 shut....this gives me a good burn until around 10:00am with the temp down to 325-350, and I then reload with another 2-3. Then, reload at apx 1:00pm and 4:00 pm.
At about 8:30am in the morning, the temp gets to appx 66-67 in the room farthest away from the insert...and by 10:00 or so its at 69-70..nice, as I don't like it too hot, and I was so used to 64 for so many years, 68 is pretty comfortable. The room with the insert gets to be about 72-74, and that room is fully open from the left/right of the house. (Temps outside were appx 25-29 all day today)
I usually run the blower on at 50-60%, as full its a little loud....don't really see a big difference in heat output at the lower speeds either. Blower works well at 50%, and realy no need to run at 100%. Pretty quiet too at 50-60%..which makes the Mrs's happy
Best thing is, by the end of the day when I put the final splits on at apx 4:00pm, the temp upstairs in the bedrooms is appx 65-66. (No need to turn on the heat upstairs for bathtime....as I have 3 little boys) Furnace eventualy comes on at appx 9:00-10:00pm...so the oil burner is pretty much silent from 7:00am to 10:00pm..not bad for only using about 12-14 splits a day. (Oil burner does some on for the hot water, as we don't have a seperate tank)
Wood that I am burning is mainly oak and maple, both seasoned appx a year. I don't put real large rounds in the insert, as the firebox is pretty small. Haven't tried to really stuff it yet, but 4 hour burns seem pretty easy with only 3 medium splits in the stove. I think if I stuffed to the gills, 6 hours would be reasonable.
Thanks for reading.
Thanks for reading.
(Older post)
Hi All,
)We don't have cathedral ceilings, and the rear of the house is open from east/west. With the front rooms boxed up a bit.(Basically, not a real open floorplan)
Thanks for reading.
