What is a normal cruising temperature on the single wall pipe?
Sent from my SM-G950U using Tapatalk
On my regency i always tried to cruise between 250 and 300 on the surface of single wall.What is a normal cruising temperature on the single wall pipe?
I'm usually in the 300s but it will get to 450 pretty fast close to 500 I start smelling paint againOn my regency i always tried to cruise between 250 and 300 on the surface of single wall.
500 is too hot.I'm dealing with a new heater and wet wood this year what would be considered to hot
It's got that hot on a reload not good aye500 is too hot.
Not good but not the end of the world either.It's got that hot on a reload not good aye
I turn the air all the way down and open it about 1 forth inch and it runs in the 300s my wife cut it all the way back one day and it smoked the window black I was gone to workThe HT2000 is a pretty easy breathing stove. I wouldn't add any pipe if you are not getting smoke spillage when opening the door. Draft is going to get stronger as outdoor temps drop. Try closing down the air sooner, when the flue pipe temp reaches about 250 and see how that works.
This wood want be a problem long..next year its going to be seasoned..thanks for all the info the manual doesn't state any stove pipe max are min temperatures. My common sense told me that 500 was getting to hotWith wet wood it is very easy to go from too hot to a smoldering mess. That’s mostly since you need lots of air to burn the wet wood somewhat cleanly. The sweet range is smaller.
What’s even worse is that you’ll have a new load going pretty much perfectly and then an hour later once the excess water burns off the fuel really heats up and delivers tons of wood gas to the fire so it can run away in the night. That water boiling off was keeping the fuel cold and dormant. When your wood is dry from the start you can really appreciate the difference.
Mine is running pretty good in the 300s but not today temps rising to the 70s with tornado warningsMany of the thermometers made for stoves are labeled with suggested ranges for operation. Too hot, too cold, ideal. The temperature ranges are specific to single wall pipe or to stove top but are a reasonable guide.
250-450 is a good range for the pipe. That 450 is really just during warm up and I’d like to see the pipe at 300-400 most of the time. Hotter at the beginning and cooler as the fuel finishes the rapid gas off stages.
Stove top is a little more interesting. I don’t mind seeing 750 there. Your cast iron clad stove will be interest to monitor. Maybe between can offer operational insight.
The hearth looks great. The mantle is very stout. I don’t know if it is safe there but maybe begreen has some insight.
Trey has the all steel HT2000. I think you are thinking of the new T5 install by gopja. I have my concerns about that mantel too.Your cast iron clad stove will be interest to monitor. Maybe between can offer operational insight.
@Trey1979 can you go up to your forum account settings and add your stove make model to the signature line? When we get a lot of postings going on it's easy to lose track of who has what. And when you get a chance, could turn off the Tapatalk signature line too. That just advertises the phone type. Here's how to do it.
https://www.hearth.com/talk/threads/how-to-post-on-the-hearth-com-forums.139782/#post-2257451
It happens to all of us from time to time lol.You’re right, I seem to have completely screwed up and merged the threads in my head. Ack!
Did I get it right?Trey has the all steel HT2000. I think you are thinking of the new T5 install by gopja. I have my concerns about that mantel too.
