Hi! I just fired up my Hardy H4 last week with the cold weather and for some reason, the temperature inside the house will not rise above 65 degrees. Everything seems to be running fine with the outdoor burner. I have the water thermostat set to 180 and it is maintaining that temperature I believe, at least the fan is only blowing off and on, not continuously. The pump is running and I can feel hot water in the pipe. The water in the system is the correct height.
Inside the house the lines coming into the heater are hot, but not scalding to the touch. Is that right? The air coming out of the vents in the house is only lukewarm however. Yesterday the house was 65 at 8:00 am and only got up to 66 after running all day.
Any ideas on things I should check? Someone mentioned that maybe there was air in the system, but I'm not really sure how to bleed off air if there is.
Thank you for your time!
