Hi,
This is my first post but I have read MANY and appreciate everyone's knowledge and enthusiasm to share.
Here's my situation:
I recently bought a house and got a stove to install. The only time I have ever installed a stove, we went straight into the brick chimney and lined it all the way up. There was nothing in the chimney.
In my new house, if you look in the basement, you can see that the gas appliances (water heater and boiler for radiators) are vented into the chimney. The fireplace on the main floor is drywalled over and I haven't punched a hole to look into it yet...
At first my plan was to just avoid the chimney and run through the wall and up the side of the house, since there is a wall-mounted air conditioner in a strategic location (and hence already a hole through the house), but running the chimney outside seems like a pain and all-around less than ideal way to go for a number of reasons...
So now I'm back to what I was hoping would be a "don't ask, don't tell" chimney situation.
My question is, do I need to redirect the vents for the gas appliances somehow if I'm going to vent the stove through the chimney? If I put pipe going all the way up from the stove, would that obstruct the proper venting of the other appliances, or can they live harmoniously together?
I was imagining that these 3" appliance vents just tap into the chimney and the vent pipe doesn't run all the way up. Is that generally the case?
It will be a 6" flue, if that makes a difference...
Trying to figure out my best option here to keep the chimney internal.
