So here is a bit of background: There is a long story behind the house I am working on, it's my first house, and I had no idea what a floor joist was called if that gives you any idea of the experience I had getting int to all this. The house needed a ton of work, I ended up having to take it nearly down to the foundation, and that needed work too. Basically where I am at now, is I need heat, the HVAC install has been extremely difficult for me to figure out, I've wanted to rebuild this house as efficient as possible, and one of the things I wanted to do for a while now was get a good wood burner installed for heating the house.
The situation: There are lots of ways people do it as I've begun to learn, essentially I think my best bet considering what I have to work with, is to use the existing flue of the masonry chimney. Technically I don't think I have to line it, but, I'm thinking it would be a wise thing to do from the get go.
Getting on the roof to measure the flue and look down it has been quite the endeavor in and of itself, I actually built a drawbridge on top of some scaffold frames, I'm kinda proud of it, haha. So looking down the flue today, I discovered it is not straight by a long shot, so I figure I'm going to have to use a flex liner. Measuring the actual flue tile coming out of the concrete cap, the actual opening of the tile, is 5 1/2" wide by almost 10" long. Doing some research I was going to get a 6" flexible kit with a Tee at the bottom so I can use the existing ash clean out. At first I thought that I was going to have to bust out some of the masonry to get the Tee into the chimney, but then I found some kits that had a Tee with a removable snout and a band strap which is a great idea, I guess I'm just skeptical of how that band strap would hold up over time and after years of cleanings, so I wondered if there are any other solid solutions for a Tee that would allow me to install it without breaking the hole out bigger.
Since I have an existing masonry chimney that does have an intact albeit slightly cracked flue liner, theoretically, I could just pipe the stove right to that and let er rip by code if I'm not mistaken, however, again I think the liner would be wise, but I'm posting this for any and all information that folks would like to add. Ok, so assuming that a liner is going to be the wise way to go, I've got a few issues to work out. I think I'm gong to forgo insulating a metal liner if I go that route, it doesn't seem necessary and that way the masonry flue will be able to heat up and hold the draw longer than as it would with the metal liner being insulated in my mind.
So, assuming all of that thus far, the biggest issue I see is that the output on the back of the stove, which I just picked up today (holy jeez was that thing heavy, I blew a wheel out on my dolly, haha, and by god does my back hurt.) it is a Hearthstone, and I'm kind of mystified as to what the exact model is, on the label is has two listed, it just says Hearthstone I and under that, Hearthstone II with a check box next to each, but neither one is checked, for Hearthstone I to the right the label says wood, to the right of where it says Hearthstone II it says wood/coal, I'm assuming it's one or the other, but I'd like to be sure somehow. The output of the stove is 6". So therein lies potential problem #1, the existing masonry flue is not that large around, so I can't fit a full 6" round flex liner down the existing chimney. I'm not sure what to do for that. The existing chimney is quite long, the chimney foundation goes all the way down to the basement floor, and measuring from the hole in the side of the existing chimney ( there is a galvanized 6" round pipe sticking out the side ) about 4 feet off the basement floor, all the way up to the top of the flue liner exiting the chimney cap, the distance is about 34 1/2 feet. (the house was originally a story and a half, i rebuilt the house as a two story with a 10/12 pitch roof, I had to extend the chimney about another 18 feet from what it was, it's quite tall now. )
I've never done any of this before, so I tried to provide as much information as possible to be helpful, hopefully it's not too much. A big thanks to everyone willing to read all of that and help toward how to get this stove installed properly
