When I found I could only just about reach the chimney flue cap from my roof, I realized I need to get a little more height (I'm only barely 5'5"), and went and found out about roof brackets. Now I need to install them and use a 2x6 as the platform. Mine has 3 slots for three nails and I know to nail them into the rafters at a max 8' spread (obviously way more than enough for my chimney sweeping duties).
I figure the extra bunch of inches will allow me to safely get my homemade chimney brush into the flue. Googling the installation procedures, I find some info but mostly on new roof construction, not existing roof modification. I have basic composite shingles in a moderately sloped roof that spills onto a deck, (not terribly far of a fall, but wouldn't want to try it).
Can I simply nail the brackets on top of the shingles once I trace the rafters from the roof edge? What is the best way to go about this.
The bracket itself is listed as galvanized steel but I'm thinking I will probably try to remove them when not in use. How do I prevent leakaage or do you think it may be better to just install it and silicone seal the nails and around the bracket and leave it?
Jay
Jay
! After a few scary moments when my drill wanted to slide off the roof, I got both brackets in. I think I may need a slightly longer 2x6' though, my scrap piece of 2x6 I was planning on using is too short. But maybe next week, I can attempt a chimney sweep. I lifted the shingles and installed the bracket with some 10d nails and siliconed the tops, then siliconed the shingle back down to the roof..
