Hello everyone, new member here. I’m great at doing the actual handiwork, but not that well knowledgeable on the technical side. My father was a chimney mason for over 20 years, but he recently passed and I no longer have access to his well of knowledge.
My old fireplace insert was scrapped due to low efficiency and degradation of the firebox. Had a small stove that was just piped up into the chimney for the past few years due to low funds but I am ready to make the proper repair. Came across a great deal on a Wonderluxe stove from a coworker. I will be sweeping the chimney and installing an insulated liner, register plate, cap, etc. My main question is what is the optimal placement for this stove in this situation? I’m going to have to extend the hearth so the stove isn’t up against the face of the chimney so I can access the dampener and have the airflow space for the blower fan. How far away from the face of the chimney do I need to be? If I’m reading the manufacturer’s label properly I need 5 3/4” minimum of hearth space in front of the stove and I have more than enough height from the floor. I know a 90 degree pipe connection is not ideal for airflow yet a lot of people still do so, would 2 45 degree pipe connections make a difference?
I understand this is not the optimal stove for this setup, but it will more than easily heat the house and would rather not try to hunt down a stove that would fit in the fireplace or spend the money on a newer insert. However I am open to all comments, questions and concerns, and if the majority rule that this is not a good idea then I am willing to change plans. Thank you.
