The chimney is a masonry exterior setup that is 30ft tall. Its 6 years old and in good shape.
The stove is a 6 year old Woodstock Soap Stone Absolute Steel Hybrid. This is our primary heat source and has been since installing it 6 years ago.
Every year I clean the chimney 2-3 times a year and we burn about 3 cords of wood a year. Because the stove is such a modern stove its stack temps are very cool. This is causing pretty gummy creosote to build up as the chimney is exterior. I can typically get about a gallons worth of dry creosote when I clean (combined through the 2-3 cleanings) it but can still see a varnish on the tile in a few places. Woodstock says run an insulated liner while the mason says its best to run the chimney as designed and built.
I am wonder if a insulated liner would actually make a decent difference in build up as well as stove performance? Stove works great but can be a pain at times to keep converter lit off. I burn decently dry wood (1 year dried) ash, maple, elm.
I can burn an entire load and keep the cat engaged and putting off great heat however the stack temps are 200 degrees roughly.
Continue on doing it as I have been or spend the money on a liner and hope to see an improvement? I dont really mind spending the money as long as it makes a difference. Thanks for the input
