Alan Gage said:Not a direct answer to your question but why not cellulose? I blew it in mine a couple years back and there was nothing to it. Supposed to do a better job of blocking air flow than fiberglass and I'd think it would be a little nicer to install.
Alan
RNLA said:I'll be doing it this summer. I would like to know if anyone has used the polyester alternative to fiberglass? Dow and one other company make this type. The distribution is not real good right now.
Semipro said:I'm using the polyester insulation in my basement. It looks a lot like what pillows are stuffed with.
I'd do just about anything to avoid working with standard fiberglass insulation.
PyMS said:Semipro said:I'm using the polyester insulation in my basement. It looks a lot like what pillows are stuffed with.
That description is very interesting, as it sounds like real polyester fibers, such as Dacron for example, rather than polyester resin being used to make glass fiber a bit more user-friendly.
I guess I'll have to do a bit of Googling to get a better idea about the actual chemical composition.
How much did you have to pay for it, relative to "fiberglass" insulation??
Henk
midwestcoast said:Anyone know any supposed benefits of it overfiberglass or cellulose. I say supposed because from what I see insulation manufacturers put out almost as much junk science and half-truths as insulation.
4acrefarm said:Don't forget the posibility of augmenting insulation with reflective foil. I use it alot and it seems very effective. It comes in vapor barior and breathable forms.
szmaine said:4acrefarm said:Don't forget the posibility of augmenting insulation with reflective foil. I use it alot and it seems very effective. It comes in vapor barior and breathable forms.
I am considering using Refletix as the first layer (staple it to the joists?) in my attic insulation as both an air and vapor barrier and to contain the next layer of cellulose in the event that we renovated the bedrooms, plaster and lather, it would contain the loose fill.
Any critique of this idea is welcome.
Semipro said:midwestcoast said:Anyone know any supposed benefits of it overfiberglass or cellulose. I say supposed because from what I see insulation manufacturers put out almost as much junk science and half-truths as insulation.
According to an independent study (which I can't recall the source for) cellulose's R value holds up better as temps drop.
It may have been this article:
(broken link removed to http://www.finehomebuilding.com/how-to/articles/blown-insulation-for-attics-fiberglass-vs-cellulose.aspx?ac=ts&ra=fp)
I get the magazine but can't access the article online without paying.
midwestcoast said:szmaine said:4acrefarm said:Don't forget the posibility of augmenting insulation with reflective foil. I use it alot and it seems very effective. It comes in vapor barior and breathable forms.
If you're installing a vapour barrier in the attic you want it to be below all insulation. Otherwise vapor can get traped & condense in the insulation below the barrier. Mold & ceiling damage possible.
If you're talking about insulating at the roof and not venting below the roof then that would be the right place for the Reflectix, but I'd be very concerned about any water leaks getting into the cellulose & no way to dry with a vap barrier in place
To get the R-value in limited thickness of just the joist bays I'd be looking at spray foam (much less worry from leaks and effective air barrier too).
IMO radiant barrier is effective for reducing radiant heating from hot roofing in summer. Needs an air-gap on the hot side or it's useless. Reflectix also gives some insulation from the bubbles, but it's an expensive option if you have a lot to cover.
