My garage aka shop is a 30x60 pole barn that has my greenwood 100 located in it which is not insulated. im looking to get it insulated before this next weekend.what are some the the options that you all have used.
By code I guess but I have no problem with any one doing it if done correctly, I am putting a wood burner in my shop and do not see the problem, I had a freind one who burned to death because a gas furnace ignited gas fumes.
Not to worried about the money right now just trying to figure out what i should use so that when im working out their this winter i dont have to be in the bibs and freezing my nuts off while im trying to work on stuff. hopefully whatever heat is given off by my woodburner will help keep it warm
Our pole barn (which now contains a shop that's about 1/3 of the available footprint) was built with 4x6 poles, with the six dimension running "in" to the inside. The exterior tin is screwed to 2x4 battens on the outside of the poles. We debated cutting 1.5" foam to fit in between the battens but doing that didn't significantly increase the over-all R value of the walls (two windows, one 5' door).
We ended up framing with 2x6s (remember the beams?) and using R19 fiberglass in the bays we created. It's pretty snug- stays cool in the summer and heats pretty easily in winter- we use a Modine Hot Dawg heater.
Note that we only did this in the shop- two interior walls, two exterior walls (it's built in the corner of the 30x40 barn). To do the barn like this would require a lot more lumber!
How do you plan to finish the interior? Just leave the insulation showing, or panel it with something?
cheap & efficient= apply kraft face fiberglass BACKWARDS = staple the paper to the wall & try to overlap the paper of the different strips tight with lots of staples. the bare fglass is facing the interior, then cover dilligently with polyethylene [4mil min] for interior vapor barrier. finish interior wall as desired.
relative permeability between interior & exterior vapor barriers or the way house was built in the 70"s kinda. rule was= interior 5x as tight as exterior. such houses were built with tarpaper between sheathing & siding. cavity held fiberglass covered with poly & then sheetrock. Built such a hous & worx great, though new science is better & more expensive for construction cost
