Hi all,
Long time lurker and I've learned a lot from you all - thanks. I hope this is the right forum...
We've poured a backyard patio around a 3' x 4' opening where we are placing a firepit. We had the firepit fabricated out of 1/4" Corten (weathering) steel and designed it as a double wall with a 4" cavity to insulate so the outer wall would not heat up too much. Both the inner and outer walls are steel.
I was originally planning on filling the cavity with sand but I'm now rethinking that as sand may be too conductive? Other ideas were pea gravel which would have more air pockets, Roxul (mineral rock insulation). I'm just sort of confused between convection, conduction, radiation, etc.
What do you all think? Whatever it is just needs to drain well as the top is open and whatever it is will have a layer of matching pea gravel sprinkled on top to match the surrounding mulch. Thanks!
![[Hearth.com] Insulation options for steel firepit [Hearth.com] Insulation options for steel firepit](https://www.hearth.com/talk/data/attachments/182/182292-3f6d28a9c85406ea303b488f47ef04a4.jpg?hash=uH5R0rUhd3)
